Sony DVD to Hitachi 42PD5200
Discussion in 'Sony TVs Forum' started by james_19742000, Aug 31, 2005.
  1. james_19742000
    james_19742000
    Oct 8, 2004
    666
    +18
    Hi all,
    I want to connect my Sony DVD to my 42PD5200, currently hooked uo using a S-Video leads onto AV1 on the Plasma, is thuis the best way or not? If not then what would be thje best way, the DVD has no scart, just red/white/yellow phono style outputs, although there is a digital output that has been taped over since I have owned the unit (from new), is it best to use that and if so what would teh lead I would need and woul it improve the picture drastically???
    Hitachi is the 42PD5200 non H model and the Soney is a DAVS500 5.1 surround sound system, only other thing is a Sky + box connected via scart to AV4.
    Any help appreciated.
    James
  2. bowler
    bowler
    Jun 8, 2003
    223
    If you do not have component or RGB scart on your DVD player then S Video is your best bet.
    Are you sure you have an S Video connection on AV1, mine is on AV3.
