Sony DVD DAVS880
Discussion in 'Blu-ray & DVD Players & Recorders' started by richkeys, Jan 20, 2003.
  1. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    Does anyone else have a Sony DAVS880 from www.techtronics.com with the multiregion chip?
    My unit seems to have a problem playing back normal CDs, any ideas?
  2. Silent Fly
    Silent Fly
    I heard about this problem before but I cannot remember where... :rolleyes: Sorry
  3. letitbleed
    letitbleed
    Nov 5, 2002
    215
    Southampton
    +4
    I have a multi-region DAVS880 (PRC Direct),I don't have any problems.
    What exactly are the problems you are encountering ?
  4. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    it's like when you put a blank CDR in a CD player. It tries to read the disk, you can hear it spin up but then I get just two numbers appear on the display 1 2 and the transport stops working?
    wierd?
  5. gsdev
    gsdev
    Feb 1, 2003
    4
    I had the exact same problem. I sent my unit DAV S550 in for service and only after changing the "DVD PCB Board" the problem was solved. Initially the technician changed the whole drive unit but this did not solve the problem. Only after changing the DVD board the problem was solved.
    Can you check what firmware version you have. You can do this by holding down the STOP & DISPLAY buttons together while turning the volume Knob clockwise.
    On your remote choose 6 (i think) for firmware version.
    To come out of the Eng. Menu, power down the unit.
    Let us know if this is another problem / bug.
