sony dvd changer
Discussion in 'Blu-ray & DVD Players & Recorders' started by carmine, Sep 8, 2004.
  1. carmine
    carmine
    i would like to purchase a dvd changer in the uk but am having trouble finding one. i have been looking at the sony dvp-cx777es but seems to be sold in america therefore will be 110 volts region 1 and output ntsc output and not pal,does anybody know if i can buy this machine for the uk market or can i modify the american version please can anybody help me
  2. mjn
    mjn
    May 24, 2001
    22,092
    Herts, England
    +9,845
    i think most Region 1 players are NTSC only, but you can get a 110 -> 240v convertor pretty cheap.
  3. Alan Pressley
    Alan Pressley
    Sorry if I am butting in, but I have owned a Sony DVD changer and would not recommend one :thumbsdow
  4. mjn
    mjn
    May 24, 2001
    22,092
    Herts, England
    +9,845
    Well, i wouldn't buy a Sony DVD player full stop.......just seem to have an endless problem with faults.
  5. sjp1966
    sjp1966
    Oct 29, 2003
    544
    Kent
    +10
    slightly off topic, but i had a Sony DAV-S800 and i had no problems at all with it. I only got shot of it when i upgraded my kit.
    I know nothing about multi changers tho, sorry :blush:
  6. andypandy
    andypandy
    Feb 6, 2002
    594
    Surrey, UK
    +10
    Well, I too own a Sony Player. This particular one is a very good one. colour definintion is particularly much better than my previous 2 models (panasonic and Samsung).
    Although news is that the Sony players have no error correcton when playing DVD's and have the most sensitive pick up lens (romour has it you will start getting problems playing disks after a couple of years depending on it's useage). Basically what this means, is that if you are into buying asian R0 copies you may get glitches in them or may stop playing at some point whereas other players will handle them perfectly.
    Oh, and I only found out about this AFTER I had bought it, but so far I am happy with mine - touch wood. !
  7. Alan Pressley
    Alan Pressley
    I had no problems with the sound and picture quality. It was the mechanics of the changer that kept getting stuck/failing to pick up discs/scratching discs/discs getting stuck etc.
    Sony said I should remove all the discs once a month and clean them so the sensor would detect them better, but removing the the discs wiped the memory.
    This meant you had to re-type the titles of the films into the menu for the discs that didnt automatically register, which was about 85% of them.
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,740
    2
    In a secret location with Jennifer Lawrence
    +9,526
    Moved to DVD Players forum
