SONY DVD-106e which mediums support?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by peros550, Apr 29, 2007.
  1. peros550
    peros550
    I recently bought the Sony DVD camcorder DSC DVD 106e. The operators manual states that trhe following disks are supported.
    DVD-R, DVD-RW, DVD+R , DVD+RW, DVD+R DL.
    The reason I am starting this thread is to be informed if the SONY DVD 106e can support DVD +or- RW dual layer. It seems to me pretty odd why they claim that only DVD+R DL are supported but not DVD+RW DL or DVD-RW DL.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I would believe what the manual says. Though it is possible that say a new +RW dual layer disc could work, but Sony didn't certify with them so they are not officially supported.
    I'm not even sure if +RW or -RW dual layer discs exist?
    Certainly the supplier I use doesn't have them
    http://svp.co.uk/
    They have mostly +R (which was the first and most common dual layer), and a few -R.
  3. peros550
    peros550
    I think you are correct. After further investiagtion I found that there are no DVD RW dual layer.
    Thanks for the answer.
    Regards
    Yiannis
