Sony DSC-U20 vs. Canon Ixus
Discussion in 'Photography Forums' started by CodeMonkey_UK, Jan 24, 2003.
  1. CodeMonkey_UK
    CodeMonkey_UK
    I'd appreciate your views on the pros and cons of the Sony and Canon models. I'm interested in getting the Sony DSC-U20, but a friend of mine says I should consider an equivelent Canon Ixus model. I don't know what the equivelant model is, but would appreciate some advice from anyone who has used either (or even both) of these cameras.
  2. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    As it happens, i spent most of yesterday looking at just this.
    The canon equivalent is either the S200 or IXUS V2.
    It looks to me that the canon is the better camera of the two, but the sony will allow faster shooting.
    If i get one, im going to test each for a bit first (probably get them from high street, return them and buy on line).
    Try here for reviews of each
    http://www.dcviews.com/
    If you do get one, can you give me your views on it.
    I'm looking for a take anywhere camera which allows for very quick/easy shooting (e.g while clubbing etc) so low light performance is important.
    Image quality does not need to be fantastic, as i'll use my 35mm SLR for proper pictures.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,349
    Windsor
    +1,028
    The ixus should be better on features, and it has a zoom. But the Sony is tiny, if portability is key.
    If you are willing to go to the larger Ixus, then you should also look at other simliar sized cameras, including the Sony P series.
  4. CodeMonkey_UK
    CodeMonkey_UK
    Thanx for the info guys. Turns out one of my work buddies has the Ixus. I had a play with it today and as impressive as it is, I found it very heavy and considerably larger than the Sony. As you said, it may not be a fair comparison due to the zoom + other features (such as greater Mpeg capacity + sound).
    I also had a play with the Sony U20 in Dixons at the weekend and it's soo tiny I think it's what I'm gonna go for - just as soon as someone starts stocking them in silver!
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Bought me a U20 for snaps when out partaying. Great to throw in the pocket, takes great photos and takes them quick. I've also got a few phone numbers based entirely on how cool the thing looks! Can't be bad.
