Sony DS1200ES centre speaker not working
Discussion in 'AV Receivers & Amplifiers' started by tardis56, Feb 4, 2009.
Tags:
  1. tardis56
    tardis56
    May 23, 2006
    39
    I bought a centre speaker which seemd to work for some time and then sound stopped coming out of it.
    I swapped it over for my Dali Vokal 2 which I know works but still no sound. On this occasion i accidentally swapped the negative and positive wires around so not sure if that did anything to it?
    I also have another Dali centre speaker and that doesn't work either - must be the amp I have concluded.
    Any ideas how i can test the amp or do i need to do the auto setup again using the remote thingy that came with the unit?
