Sony DRU-500a DVD burner...
Discussion in 'Desktop & Laptop Computers Forum' started by Rad, Oct 13, 2004.
  1. Rad
    Rad
    Jan 31, 2002
    698
    Scotland
    +4
    Does anyone else have one of these, if so what firmware version do you use and what make of blank DVD's.
    I bought some bulkdata 8x disks from Novatech which won't work so I don't want to get it wrong again.
    Cheers,
    Rich
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I had a 500A using 2.1a using Ritek -R x4s just fine., never tried 8xs as I had no need.
  3. HMHB
    HMHB
    Nov 11, 2001
    27,188
    Nottinghamshire
    +6,125
    My 510 only burns at 4x so I only buy 4 speed discs - I always buy the ones using the Ritek G04 dye and always -R discs - I've never had a problem.
    If you buy from SVP (aka blankdiscshop) they give a list of compatible drives for each type of blank media. I'm sure I've seen somewhere that you shouldn't use 8x discs if your drive can't write and 8x.
  4. Rad
    Rad
    Jan 31, 2002
    698
    Scotland
    +4
    Thanks guys,
    I should really read things before I buy them in future :suicide:
    Cheers,
    Rich
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    :) .. easily done, you'll just have to force 4x speed on these 8x discs and they should be okay.
