Sony Digital - Program planner
Discussion in 'Satellite TV, Sky TV & FreeSat' started by uk_jih, Mar 17, 2003.
  1. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    On my Sony digital box, the program planner tells me between 5 and 15 minutes after a program has started that it is about to start. My Grundig box does not have this problem.
    Anybody out there with the same problem?
  2. Fernsehman
    Fernsehman
    Try switching the Sony box off at the wall socket for a few seconds to "reboot" it.
  3. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I have done that a few times but it does not help.
  4. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    I have a sony box and does it as well!
    Bug with the software I would imagine - seeing as they don't do sony boxes anymore it will probably never get fixed!
  5. Sam Fox
    Sam Fox
    I take it that it is no longer under warranty? Have you spoken to Sky Technical Help?
  6. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I would not waste my time. I may ask sony though.
