sony digibox optical problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rhinoman, Jun 8, 2002.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Just had my new sony digi-box installed, connected it up to my amp via optical out and....nothing. Well very little. I have to turn the volune control on the amp right round to nearly full to barely hear any thing at all. The amp is also a sony, strdb940.
    The optical out if connected at the digibox but not the amp shows a red glow so i assume its working.
    Any body got any ideas? Is it buggered or am I just missing something simple? It works fine via the analogue outputs.:(
  2. Steve_e42
    Steve_e42
    John, I assume you have assigned it correctly? I have a sony box connected to my sony 870 amp using the optical, but I have to specify coax in for the Sat/Tv setting.
  3. Steve_e42
    Steve_e42
    grrr.. not coax.. i meant optical.. sorry
  4. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    The sony digibox optical audio was a feature that Sky TV didn't sanction & Sony had to disable it in the software.
    I think that each time the digibox software is updated it toggles the output on/off.
    If it is currently off:
    1 remove mains power
    2 hold in 'back up' button on front panel
    3 connect mains power (holding button in for about 20 secs.) until all front panel lights come on. release button.
    4 wait 10/15 mins until digibox is in stand-by (red led only)
    5 press Sky button & wait for digibox to re-boot (2 mins)
    this should turn the optical output on
    press 'services'
    4 system setup
    2 sound
    line two - turn up to full
    NB
    this digibox runs very hot & needs good ventilation
    Hope this does the trick.
  5. G.M
    G.M
    What model of sony digibox are you talking about, the 750 or
    760? How much is it for the digibox only?
    regards,
    G.M.
  6. Fartpants
    Fartpants
    I got a 760 attached to my 925 (yes the one before the 930) amp via a Btech optical switch (remote control) into the DVD input.
    The Swtich has 4 inputs (I use them for DVD, CD, SKY and Humax sat receiver for may motorised dish), 2 outputs (one to the Amp the other to the mini disc). I don't use the Coax input at the moment.
    Never had to set it up special, but in the old days when I ran both coax and optical the Sony defaulted to the coax, so had to be manually switched.
    Regards
    Dave
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Guys
    Tried the reboot to the sky box and its made no differenc and the volume setting output was already turned up to full.
    My sony 940 has an optical input lables tv/sat which is the input I am currently using with the analogue leads, can someone tell me how to select the optical input, I thought it did it automatically.:confused:
  8. Fartpants
    Fartpants
    Not sure if it is the same as mine, but there is a button behind the fold down bit.
    Just a couple of thoughts.
    1) Try the DVD input to see if that works.
    2) (Might sound silly but) Is there a little clear plastic thingy on the end of the optical lead?
    Dave
  9. hitz
    hitz
    Dec 18, 2001
    68
    I have exactly the same problem - with sony digibox and sony STDBR940 reciever.
    I connect it to the TV/SAT and nothing. I dont believe there is a setting on the reciever to say - use optical input - i tried to search but no luck. gave up in the end - and am using analogue inputs.
  10. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    315
    +22
    I have a sony 760 connected via optical cable to Yamaha E 800 processor and I get no sound. However connecting to a Sony minidisc recorder it works o k. Anyone any ideas?
