Bacus
Hi all, i have a question.. I have sony digi box model VTX S760U. On the back is a computer type output with RS232 on it. What is this (svga ?) can it be used to output a picture from sky box to telly ?
Thanks for that, does that mean this box can get software updates ? if so how does that work ?Flimber said:AFAICR, it's diagnostics/firmware updates. Deffo not signal-bearing.
Mike.
Nick_UK said:Most digiboxes have RS-232 ports. They are used to program and test the unit in the factory. Not really of much use to the consumer - all firmware updates are done via the dish.
