Sony DCR-TRV140E & Pinnacle Studio DV version 8
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by infoBlip, Jan 26, 2003.
  1. infoBlip
    infoBlip
    Has anyone used the Sony DCR-TRV140E with Pinnacle Studio DV version 8? pros? cons?
    or basically whats the best capture card/software out there for my camcorder or what are you using to grab the best quality movies from this camcorder?
    infoBlip
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Quality is not an issue when transferring/editing on DV. All capture etc is done in digital and therefore the quality stays the same.
    Pinnacle studio 8 is a great, easy to learn package.
    Mark.
  3. infoBlip
    infoBlip
    Thanks for the reply, as it happens I borrowed a card C/W dazzle LE from a mate who's taken it out due to lack of use. The card worked fine on Vegas 3.0, (waiting for 4! got beta) of which i'm used to using and really wanted to use it on. To my suprise, it captured fine on my over fragmented HD without dropping a single frame! though I'll use my clean HD once I get myself sorted.
    btw,
    The header was that I was going to try Pinnacle instead of Vegas, magazines gave it flying colours, but I read loads of bad consumer reviews of blue screening, hangs, etc..
    infoBlip
