Sony DCR-SR32 to Toshiba 37WLT66
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by kevin_Fozzy, Sep 21, 2007.
  1. kevin_Fozzy
    kevin_Fozzy
    Sep 21, 2007
    12
    Hi I have had the 37WLT66 LCD fo a while now and have just bought the a Sony DCR-32 camcorder. I seem to be struggling with the image quality after recording inside. The recording is not unwatchable but just does not appear very sharp. On a normal CRT (28") television the picture is much clearer. Is this a common problem ? I have played around with all of the settings on the tv and camcorder but dont seem to be able to find a picture I am totally happy with. Any help would be greatly appreciated. Thanks.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I think it is simply due to:
    - The SR32 is an entry level HDD model; small sensor, performance indoors/low light is not that good.
    - You notice the quality much more on a larger screen.
  3. kevin_Fozzy
    kevin_Fozzy
    Sep 21, 2007
    12
    I thought that might be the case, what sort of improved quality would I get from a camcorder that uses tapes or discs for the same sort of budget £300 - £350. Or alternatively how much more would I have to pay for a good improvement on a HDD, I am guessing from other posters that the next step up would be the SR190 ? Is this camera really that much better?
    Thanks for any help I'm a complete novice to camcording but a new arrival to the family has kicked me into investing in one. I'm not sure if I should be dissapointed with the quality or if its just that I was maybe expecting too much!
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    There is a pretty big difference between the SR32 and either the SR190, or a DV model like the Sony HC96 or Panasonic GS320. Those 3 models are roughly similar in quality, but the SR190 costs £100 or so more.
    Having said that, any camcorder will do better in good light; adding a video light, or even simply turning on more lights in the house can make a difference too.
  5. rhubarbe
    rhubarbe
    May 25, 2005
    4,675
    Cheshire
    +211
    And even the 190 isn't a patch on the old 90, is it?
  6. kevin_Fozzy
    kevin_Fozzy
    Sep 21, 2007
    12
    Thanks for the replies. After some playing around with the settings I am a little happier with it although still not great under low light. I am now undecide as to take it back and get a refund which I have 5 days left to decide ! or stick with it. A mate has also decided he wants to sell his Canon mv830i. Is this any better and what sort of price should I be willing to pay for it 2nd hand? (I believe it is still in good condition having not been used too muh)
    Kev
  7. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    MV830i will be probably slightly better, but it is still a small sensor model. The new Canon MD101 will give you about the same quality; you can buy those new for well under £200.
