We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Sony DCR-HC90E and Windows Movie Maker
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by monkeyleader, Oct 21, 2005.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,620
    71
    Cambridge, UK
    +87
    So I wont be sticking with Windows Movie maker but just thought Id give it a go since I have it installed on my system. It picks up the camera and when I choose capture it rewinds the tape and starts to play it - but nothing comes up in the preiview window and nothing gets captured?
    Thoughts?
    Nige
  2. Roy Mallard
    Roy Mallard
    If you are running WinXP with SP2 then you need to get a hotfix to enable full speed firewire connection, in some cases 1EEE1394 devices on XP SP2 run at a reduced speed of 100MBs as opposed to 400MBs.
    Check on Windows update site (don't go through auto update, manually check)
  3. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,620
    71
    Cambridge, UK
    +87
    So I dont suppose you know which hotfix - I've gone to the website and downloaded the latest updates - no more left to install. Still problems.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,629
    Rainham Essex
    +2,551
    I think This should fix it.
    Mark.
  5. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,620
    71
    Cambridge, UK
    +87
    Thats the ticket - thanks a lot guys :)
