B
barnabydog
There is a battery fault that has been well documented on a USA based camcorder forum. In essence the unit discharges the battery when switched off, usually characterised by the memory stick lamp flashing. There are also other related issues, such as the mode change switch misbehaving.
I cannot find any reference to this fault on this forum - has anyone any experience of this? Is it a generic fault that is known to Sony UK?
Regards
Regards
