sony DCR-HC19E firewire cable???
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by scramfromroro, Jul 3, 2005.
  1. scramfromroro
    scramfromroro
    Hi i have just bought a sony DCR-HC19E and was told i needed a firewire cable but i have no firewire port on my PC. Is it possible to use the USB cable to transfer to my hard drive. What is the firewire for?
    Please help
    roro
  2. Brian110507
    Brian110507
    it is possible to use USB if you want low quality video pictures but for high quality and easy transfer you need firewire - a PCI card and cable are quite cheap see HERE they are very simple to fit to your PC taking only a few minutes and virtually no knowledge of a computers insides.
  3. 90210
    90210
    Hi, as the other post says they are easy to install. Believe me if I can do it a trained chimp can !The hardest part was actually getting the outer case back on once i had done it! I was very proud of myself after it was completed!!! :)
