Sony DB925 Protection ON!
Discussion in 'AV Receivers & Amplifiers' started by stammerman, Sep 5, 2004.
Tags:
  1. stammerman
    stammerman
    Sep 5, 2004
    50
    Hi!
    I've had a Sony DB925 for the last few years which has given pretty good service, but now when I power on the amp, a message is displayed saying 'Protection on'. The manual states that this indicates a short circuit and that you must identify the short circuit to fix the problem.
    I've pulled out all the cables, so I only have the power lead in, but still this message is displayed. Is it worth getting this fixed (they charge around £50 here in Sweden just to tell you what is wrong with it) or is now the time to replace it?
    Cheers,
    Martin
  2. John7
    John7
    Aug 6, 2004
    2,362
    116
    +646
    I used to have one of those.
    I seem to rmember there being an "all reset" function which basically resets the CPU and all functions to the factory defaults. It might be worth trying that as a voltage surge or static discharge may have triggered the protection circuit.
  3. stammerman
    stammerman
    Sep 5, 2004
    50
    Thanks for the advice John, but it hasn't fixed the problem. Looks like now's the time to replace it.....Cheers....Martin
  4. coalfield
    coalfield
    Mar 26, 2006
    1,461
    Sandhurst, Berkshire
    +51
    I am having some trouble with the same amplifer. The centre channel has dropped out and there is some unusual static coming from it when taking a DD input.
    Does anyone know how to hard reset this amplifer as I am hopeing this will fix it :lease:
  5. MrPudding
    MrPudding
    I had the same problem on my Sony db925 which to be honest served me well for over 5 years. The protection use to come up on mine when the subwoofer kicked in.
    I tried turning it all down but it wouldnt have it. I cleaned, checked all the wires and it still would do it, so i guess its had its time.
    However i can still use it on a low volume, but overall i think its time for a new amp!
