Sony DB790 and Tannoy FX5.1
Discussion in 'AV Receivers & Amplifiers' started by Precizion, Aug 31, 2004.
Tags:
  1. Precizion
    Precizion
    Jul 14, 2004
    Been researching a bit for budget amps and speakers, and these two seem the best in my price range, but can anyone say whether they would make a good match or not?
    Also wouldn't mind picking either up second hand if anyone has them (will probably post a classified ad here soon).
    Thanks.
  2. 42PW33
    42PW33
    I'm thinking of buying the same! Except the 790 has been superceeded by the 795.
    Try www.robertwhyteltd.co.uk 199.99 for the Sony
    Also this place for the Tannoy FX5.1 including front speaker stands for 170.00 delivered.
    http://www.petertyson.co.uk
