Sony DB780 to 3805
Discussion in 'AV Receivers & Amplifiers' started by Roguey, Aug 23, 2004.
Tags:
  1. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    hi, what would i get more from an 3805 than a Sony DB780?
    the Sony DB780 cost me around £300ish over a year ago (well now they are like £230ish - thats even if u can find a place which sells them)!
    i know more things to play with, but what about performace? would i get a better bass on my fronts? is the bass with my Q7 and DB780 is soo weak, its like there just little monitor speakers. I will be thinking of bi-amping them, will that give better mid/bass ranges?
    thanks for ur replies
