Sony DAVSC8 - Is there a remote multiregion hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Sicilian, Jul 2, 2004.
  1. Sicilian
    Sicilian
    Jun 8, 2004
    1,250
    48
    North London
    +27
  2. Sicilian
    Sicilian
    Jun 8, 2004
    1,250
    48
    North London
    +27
  3. Sicilian
    Sicilian
    Jun 8, 2004
    1,250
    48
    North London
    +27
    After some searching I found this that works, you need a oneforall Kameleon or Mosaic (I used a Mosaic)
    1. Add a DVD Device with device code 0533
    2. Using key magic feature prog buttons 1-5 with the following codes:
    1 - 189
    2 - 255
    3 - 095
    4 - 221
    5 - 079
    3. Turn player on then press 'EJECT' & 'PREV' buttons together, whilst holding them depressed press 'VOLUME +'. This will take into service in mode.
    4. Press the progged buttons on your one for all in order 1 through to 5.
    5. Your player should now display 'DATA RESET'.
    6. Press the power button on the player.
    7. Unplug the power for 5-10 seconds.
    8. Plug it back in & enjoy multi region.
    Got the info here http://www.regionfreedvd.net/player/sony.html
  4. wednesday
    wednesday
    Do you think this would work for the DAV SC6?
  5. Sicilian
    Sicilian
    Jun 8, 2004
    1,250
    48
    North London
    +27
    Yes m8, pretty sure it will.
  6. hypnotoad
    hypnotoad
    Can anyone tell me how to program the kameleon 4 with the three digit codes....cant seem to get em to stick...
    thanks
  7. wednesday
    wednesday
    Yeah, I'm having the same problems as well. I've got the Kameleon 4, and in the manual where it talks about the 'Magic Key' function, you need a 5 digit code, but those ones are 3, and so don't work.
    Do you have to use Kameleon 6 instead? Or are all the remotes with the Magic Key function, 5 digits?
    Thanks for any help
    Kayleigh :)
  8. Kev
    Kev
    Hey m8, i got a sc8 on the way, where do i get a mosiac ?
    Kev
  9. Kev
    Kev
    What key presses do you use on a one for all remote to do the above? Lost the manual so can't remember how to program the buttons 1-5 with each of thos 3 digit codes.
  10. costantinos
    costantinos
    A normal one for all remote can not do the job?
