Sony DavS888 NTSC Region 1 Problem
Discussion in 'Home Cinema Buying & Building' started by lammas10, Dec 1, 2003.
  1. lammas10
    lammas10
    Hi, Can anyone out there help me ???
    I have just purchased a Mulitiregion Sony Dav S888, when playing Region 1 DVD's the picture is in black and white.
    I understand that this is due to my TV only being a PAL television. Is there anyway around this without buying a NTSC to PAL converter as I understand the picture quality isnt the best.
    On reading the instructions it says the Asian/Australian models has a PAL/NTSC selector on the menu. I have gone into the settings and I dont have this option. Is there a hack to get this option ??
    Many Thanks
    Jay (lammas10)
