Sony DAVS880
elmbeck
Established Member
Just bought a DAVS880 Cinema surround/DVD.
Absolutely brilliant... apart from the remote.
If I'm at an angle of less than 45 degrees from the unit, the remote won't work. Is this normal?
bobble
Established Member
Hi, I have the DAVS550 and the remote with is will only work in about the range you describe, dont know if it is the same remote but it has a blue background and glows in the dark,
Do you have any problems with subtitles on this unit, such as coming on all the time and coming back on at the layer change?
Thanks.
elmbeck
Established Member
The remote is the same as the 550 - crapola - thought it might be just new batteries needed.
RE the subtitles - check some of the other Forums - (search for DAVS880) - i remember seeing something about a possible fix??
⭐ Bowers & Wilkins 600 S3 Home Theatre Speaker System Review
Back
