Sony DAVS880 vs Denon AVR1803 + KEF KHT2005
Discussion in 'Hi-Fi Stereo Systems & Separates' started by bobthebuilder, Feb 17, 2003.
  1. bobthebuilder
    bobthebuilder
    I am currently in the process of deciding speaker system and receiver I should buy. I have narrowed it down to the Sony DAVS880 and the Denon AVR1803 + KEF KHT2005.
    I am currently edging towards the DAVS880 since it looks damn good and the DVD player has progressive scan (or so that I have read). It is also the cheaper of the two setups. Please note that since I am getting a Philips DVDR890, the fact that the DAVS880 comes with a DVD player is just an added bonus, so if I do go down the separates road I will not buy an extra DVD player.
    What do you guys think of my decision?
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Go to sleep, wake up, buy separates, forget about 880 :smoke:
  3. bobthebuilder
    bobthebuilder
    When I demoed the two systems I thought that there was very little between the two. Since I won't be upgrading the system till I buy a new home cinema, I don't think upgradability is paramount.
    But then I don't know what to listen for in speakers. I will be going again tomorrow with people who know what they're talking about.
    Thanks for the reply.
  4. Silent Fly
    Silent Fly
    I have a Marantz SR5300 + KEF KHT2005.
    The past weekend I had a quick demo of the Sony DAVS880. Nice compact system, easy to set up, I like the style of it.:cool:
    Sound-wise? Personaly I think there is not comparison. If you can afford it, buy AVR1803 + KEF KHT2005.
    Another valid option can be:
    Marantz SR5300 + KEF KHT2005 :D or
    Sony 630 + KEF KHT2005
    with Toshiba 220
  5. bobthebuilder
    bobthebuilder
    Thanks for the advice.
    I went to get the two systems demoed again by somebody who knows what they are listening to. The DAVS880 wasn't even comparable to the KEFs. I am now going to purchase the Denon AVR2802 with the KEFs.
    Thanks again.
  6. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    if you want to improve the setup even more try demoing a different sub to go with the eggs.
    I was happy with my 3802+KHT2005 for several months until I demod a different sub... couldnt change it quick enough after.
