SONY DAVS800 speaker problem
Discussion in 'Home Cinema Buying & Building' started by Dingbat75, Jan 10, 2005.
  1. Dingbat75
    Dingbat75
    Jan 10, 2005
    69
    Norwich
    I have a davs800 had it now about 2 yrs and contrary to what other people say I think it's brilliant, it gives good sound especially when watching movies with DTS.
    But system has developed a problem the left front speaker has stopped giving out sound and can't figure out why. all other speakers work fine. any ideas on a reason and solution to fix it.
  2. thewul
    thewul
    Oct 1, 2004
    275
    +15
    possibly dry joints in the power output stage, the 400 suffers from this and the pcb is similar in the 800
  3. rich80
    rich80
    I've had the same problem myself on my S800.
    It would appear from previous threads that this is not an uncommon problem for many owners - check this out...
    http://www.reviewcentre.com/review32754.html
    I know this doesn't directly help you but at least you know you are not on your own!!
    Regards
    Rich
