Sony DAVS550 region free?
Discussion in 'Home Cinema Buying & Building' started by ubik, Mar 7, 2003.
  1. ubik
    ubik
    I want to buy this from John Lewis because I can get £100 off it
    (so £350) but they obviously can t make it region free like say richer sounds can.
    Does anyone know of an easy hack for it?
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    www.dvdchips.co.uk
    and go for a nice solderless upgrade!!!! (you rent an upgrade remote)
    JJ
  3. ubik
    ubik
    nice one,
    cheers
  4. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    If you've got a local SuperFi, they might do it for £30 ish.
    It can't be done by remote (so I'm told)
    I Think Super Fi also pricematch, and they will definitely upgrade for £30 if you get it from them. I got mine in October from their Sheffield shop, and thoroughly recommend them.
    Have a look on their website. www.superfi.co.uk
  5. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Not by the original manufacturers remote it can't, but there is an IR code that will work, that is programmed into the remote you "hire" from dvdchips :)
    K.
