Sony DAVS550 Owners, needs info
Discussion in 'Home Cinema Buying & Building' started by pat22, Jan 22, 2004.
  1. pat22
    pat22
    I am interested in the Sony DAVS550 to be connected to a projector (either the Z2 or EA500).
    I would I appreciate if some of you have the answers these questions:
    - Can it play DVD+R and DVD+RW?
    - Does it support Pal progressive scan?
    - Does it reads JPG?
    - Is there a multiregion crack available?
    - Is there a PDF of the operating manual available?
    Many thanks
    Patrice
  2. DDDavo
    DDDavo
    Ok i can help.
    However you have asked a really hard question.
    Firstly then:
    Sony's aren't advertised as being able to support home media recordable formats except CD-r and rw. However the majority if not all play dvd-r
    The Rw of these formats can be a bit touchy having said that they will probably (probably) play. The + format is another touch and go and i would say that could be risky as its the - format that is more widely supported. Especially +rw. The thing is you have to try it with your player to see!
    Next:
    It does support pal progressive on compnent out (which you should use with a projector for optimum quality)
    It reads a VCD with jpeg pictures burnt onto it
    Some sellers sell multi region versions of this player and you can borrow remotes which unlock it to multi region format for around £20-£30 (forgot the site) however sony themselves don't support multi region versions.
    Manual, sorry don't thinks so. Sony will send replacement booklet form manuals out but i think they will probably charge!
  3. pat22
    pat22
    Thank you
    Supporting Progressive PAL! That would be great.
    I wasn’t sure as I read that progressive scan was only working for NTSC.
    Patrice
  4. DDDavo
    DDDavo
    Right i have just checked that.
    Using component out:
    Set it to progressive and the colour system of the TV is pal, the signal is changed into interlace format automatically.
    I don't use c/out you see. I would check this with some one who can be sure, but i am pretty certain it supports pal progressive
  5. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    The Davs550 has a very nice pal interlace picture plus of course ntsc progressive scan. Your projector will de-interlace this interlace image to progressive scan and this will be a marginal reduction in quality compared to the dvd player de-interlacing. Personally I wouldn't worry about the lack of pal progressive you still get a very clean and detailed component out image that I think you will be very happy with. In comparision the s-video output is a little grainy.
    The DAVS550 is not as flexible at reading other media as many systems out there but as previously stated most good quality dvd-r copies should work but not all. Sony own television program and film production companies and using copied media has never been a priority for them in fact they have often worked against playing copied media.
    The Sony is a nice system if your making use of its component out socketry and its sacd playback is excellent. Its not as dynamic as other systems but its digital amplifer produces a lovely detailed sound. Note that the system isn't as loud as many on the market and its output compares to about a 30 watt per channel analogue amp based home cinema system.
