Sony DAVs550 and Goodmans LCD
Discussion in 'Home Cinema Buying & Building' started by Docta teef, May 29, 2004.
  1. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    Does anyone know if any of the command codes for the remote will work with Goodmans LCD tv s i could sit and go through all the codes to check but its a bit of a ball ache to do so. :devil:
  2. DDDavo
    DDDavo
    hi!
    Well i don't think you'll have much chance of it working. I had to go through each code (doesn't take too long) and some would (not for my manufacture of TV) but some codes would bring the TV out of standby and change channel but thats all.....
