Sony DAVS550 - £270
Discussion in 'Shopping, Deals, Discounts & Bargains' started by amar_fiaz, Nov 27, 2003.
  1. amar_fiaz
    amar_fiaz
    This already maybe common knowledge but Richer Sounds have reduced the price of the multi region version of the DAVS550 from £200 to £270. I've bought one myself, after researching the cheapest prices elsewhere...no one beats Richer!!
    AMAR
  2. DVDcake
    DVDcake
    Jul 1, 2002
    469
    Invading Surrey UK
    +3
    Was £200, now £270. Reduced?:confused:
  3. amar_fiaz
    amar_fiaz
    You could be thinking of the DAVS400, which i think is even cheaper at around £180 (if you can find one). But £270 for a multi-region DAVS550 is the cheapest i've seen anywhere (no one will even price match!). And you can get the region2 model for £250 (again cheapest i've seen anywhere).
    Unless of course someone knows different and has seen them even cheaper
  4. devastator
    devastator
    May 15, 2002
    1,511
    48
    +49
    I think he means, in your original post you stated it was reduced from £200 to £270.... (bet you failed in maths ;))
  5. amar_fiaz
    amar_fiaz
    Yep, you spotted the deliberate mistake!!
    Of course what i mean't to say was "Reduced from £300 to £270..."
    Thanks for pointing that out guys ;-)
