Sony DAVs speaker stands
Discussion in 'Home Cinema Buying & Building' started by somebugger, Aug 21, 2003.
  1. somebugger
    somebugger
    Has anyone found a cheaper alternative to Sony's speaker stands that fit the DAV's range ? Cheers
  2. shyewei
    shyewei
    Dec 11, 2002
    5,342
    London
    +189
    Hi!
    If your looking for wall mounted stands, Richer Sounds do nice Vivanco ones at £9.99 per pair. Look quite nice and work just fine.
  3. somebugger
    somebugger
    Got Sony brackets already, cheers anyway.
    I have found alternative stands though, made by Avia and in Argos at 34.99, fit the DAV's speakers perfectly.
  4. ibrox
    ibrox
    Hi;The Sony Dav 550 proper stands were in Comet for £35 if this helps.
