Sony davs s880 or Panasonic XRSYSTEM
Discussion in 'Home Cinema Buying & Building' started by zerocool242001, Mar 19, 2003.
  1. zerocool242001
    zerocool242001
    Ok heres the crack, saved up a bit and got the money for either one, which one should I buy,
    Someone told me both are 600W, is this correct? Does the DAVS skip on some dvd-r's too. I've got loads of dvd-r's and don't want films skipping or freezing.
    Opinions and help will be appreciated.
    Thanx:smoke:
  2. nickdhall
    nickdhall
    recently got the davs880 and am over the moon with it... yeah its 5x100w with the sub 100w too...
    have got a few cd-r disks and have had no problems at all...
    plus i've yet to see a better looking system!
  3. zerocool242001
    zerocool242001
    Thanx nickdhall
    thats reassuring, hav u tried it with dvd-r films, got loads and if it skips, etc, then i'll stay away from it.
    Just a quick one as well, in addition to the sony sub, does it have an additional subwoofer preout at the back of the system, might add another sub which I already have to it thats why.
    Cheers m8
  4. nickdhall
    nickdhall
    not 100% sure but almost certain you wouldnt be able to hook up your additional sub... dont hold me to that though as not posative...
