Sony DAVS 880 - Which Brand of CDR
Discussion in 'Home Cinema Buying & Building' started by mrmc74, Jun 8, 2003.
  1. mrmc74
    mrmc74
    Nov 28, 2001
    122
    Netherlands
    Has anybody got any advice on which brands of CDRs will work on this machine and which won't?
    I want to record MP3's and vcd's.
    Thanks for any advice.
  2. nealb
    nealb
    Nov 15, 2002
    193
    +5
    should really have any problem but try and stick to branded ones as they are generally much higher quality and more compatible.
  3. mrmc74
    mrmc74
    Nov 28, 2001
    122
    Netherlands
    I've tried maxell and traxdata, neither of those work on the sony, but will work on other hifi cd players.
  4. leesbriggs
    leesbriggs
    I have used princo, bulkpaq and memorex without a problem. It plays CDR's so should be fine with all media.
