Sony DAVS-550 Vs Sony DAVS-888
Discussion in 'Home Cinema Buying & Building' started by Dave Harrison, Sep 9, 2003.
  1. Dave Harrison
    Dave Harrison
    First off, I hope Ive done this right ! I have a Sony DAVS300 and althought the image and sound quality is good, normal CD's are very poor. So, I thought I would upgrade and go buy a new out-of-the-box system.
    I have my eye on a DAVS 550 or a DAVS 888, both have seen their price drop so much, thought it was a good idea to get one, but Ive been to many, many sites for independent reviews and I have to say that it's a real mixed bag. Some sites tell me the 550 has poor bass and to avoid it, so I'll look at the 888 instead, only to find it's a love or hate situation. Too bassy, or 10/10 !
    Also, I have connected my DAVS300 via SCART-Phono cable, is this the best way to connect ?
    Can anyone with decent knowledge of the whole DVD-thing gimmie some advise please ? I will be forever in your debt !
    Thanks everyone.
    Dave
  2. PaulJ
    PaulJ
    I have the DAVS550 and have been very happy with it. The picture quality through S-Video is very good. (No RGB, as no scart).
    I found the bass to be very good, although I have never used seperates, so can't compare to that. My last all in one system was a Philips LX3000D and the Sony is far superior in terms of sound.
    I don't have the largest of living rooms and I place the sub in a corner facing outwards into the room, so these factors may help.
    Regards
    PaulJ :smashin:
  3. Dave Harrison
    Dave Harrison
    Thanks Paul, I must admit my Bro-in-law has the DAVS500 and I think it's great, so the 550 must be same / better. Nightmare trying to choose ! Ta. Dave.
  4. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    If CD audio is important to you, surely an 'upgrade' to another all-in-one isn't the way to go?
    As I've said twice already this morning :laugh: , I own a Pioneer DCS-303 all-in-one and although I am happy with it, it is far short of what even a 'low-budget' separates setup has to offer - even one used for AV, in my experience.
    Hmm, I suppose 'far short' reads a little more critically than I intend. I just mean to say that the 'mid-range' audio is lacking - particularly noticeable on hearing a big-box system.
    There are one or two all-in-ones that have had reasonable reviews (for what that's worth!) in terms of their capacity for music playback; but I doubt that anything is a substitute for full-size speakers...
    Re: your video question, I don't think it's been specifically answered, but I think you're saying that you are using a composite connection. If so, that's the worst possible method for playback. Depending on your TV, cabling and the playback hardware, you'll find that component, RGB SCART and s-video connections give the most pleasant colour and detail levels. S-video is the 'in-between', being an improvement on composite, but generally not up to the levels of component or RGB SCART. In my own experience, s-video shouldn't be discounted as it can still provide a delightful picture.
    Hope I've written something of worth during this early hour! Good luck!
  5. Dave Harrison
    Dave Harrison
    Thanks for your comments, great to get help when yopu need it !!!!
    TA
    Dave
  6. jaybeegee
    jaybeegee
    Jan 8, 2003
    73
    machester
    Can anybody confirm if sony have solved the image freeze at layer change bug that were widely reported in the forum many months ago?
    jay
