Sony DAVS-550 problem
Discussion in 'Home Cinema Buying & Building' started by bertiebasket, Jun 18, 2004.
  1. bertiebasket
    bertiebasket
    Hi just wondering if anybody can help me,
    I've got a Sony DAVS-550 DVD player/amp and a panasonic TX28PL12 TV, I want to connect the DVD player to the TV using the component outs and have attempted to do this with a profigold PGV372 component to scart cable into one of the TV's RGB enabled scart sockets, unfortunately I am not getting any picture at all.
    Can anybody help?
  2. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Are you trying to get a tv picture or dvd? Ive got a 550 in the bedroom connected to a 15" lcd tv ive found i can only use tv component input for dvd and have to composite for video out
  3. bertiebasket
    bertiebasket
    Using it for DVD
  4. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
    Is there any difference flicking the prog/interlace switch as it only does ntsc prog?
