sony davs 550 multiregion?
Discussion in 'Home Cinema Buying & Building' started by jamesandvin, Dec 15, 2002.
  1. jamesandvin
    jamesandvin
    I just bought a davs-550 from Richer sounds. It was claimed to be a multi-region model but I just noticed it has the Region 2 symbol on the back of the machine. Short of buying and trying a DVD from another region, how can I tell if it truly is multi-region?
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    I would guess the symbol is put on by Sony - they are R2 when they leave the factory and chipped to make them MR.
    A quick call to RS customer services people should clear things up. If it doesn't, don't worry too much about buying a multi region DVD - If RS sold you a Multi Region player that's incapable of playing Multi Region disks, then you can get your money back / new player under the sale of goods act.
  3. renotech
    renotech
    Don't worry about the symbol on the back, just try out some
    other region disks. Also - ENSURE you don't have the
    subtitles bug - search for dav-s550 in this forum for instructions
    on that.
  4. cadmeister
    cadmeister
    Nov 12, 2002
    107
    19
    Milton Keynes, UK
    ...and make sure it plays an RCE disk like the Region 1 of Spiderman
