TWE
Where do i start, for the spec of this system go to sony europe and download spec, it does more then most of the specs advertised you see on websites.
Right i can only compare it to my mates system which is a LG H552TH my sister in law has a system but not sure what it is but either way this beats it hands down.
The fitting of system is lets say easy to medium depending on your IQ lol, but all cables are colour coded so are speakers and connection poits so you cant go wrong.
The set up on screen is easy, you can adjust each speaker the distance and how much DB you require from speakers with ease on screen as well as all other stuff.
The sound is one word Fantastic the LG H552TH is not a patch on this nor my sister in laws, but with 1200w what do you expect, once you got your speakers with right settings and subwoofer with base leval right the sound is cystal clear with the clarity of depth if you understand this.
Also you have upto 8 settings of surround sound from 2 types of prologic to 3 types of cinema sound plus others.
I cant praise the system enough even though there are 3 minor things for me,
1. It takes a while to register DVD when turned on well i say about 15sec this might be me being picky.
2. The wirless rear speakers the adaptor which connects them and plugs in the wall is a bit big for me, once again could be me being picky.
3. The base of the stands being big, if you stand it in the corner the speaker is about 10inch away from wall, but do what i done and attach them to the wall looks better in my eyes anyway.
Comet are selling it for 499 i got it for 359 from Digital Direct next day delivery.
Overall- Well worth money great system fantastic sound.
Hope this helps if you require any more info let us know.
Sianba
