Sony DAVDS-1000 or Pioneer NS-DV1000?
Discussion in 'Home Cinema Buying & Building' started by bbcms, Jul 8, 2004.
  1. bbcms
    bbcms
    Hey
    Trying to figure out which of the above-mentioned systems to buy. It is proving impossible to find any reviews on the Sony whereas quite a few are available on the Pioneer.
    Any advice or info would be much appreciated - espicially concerning the performance of the Sony.
    And - are there other systems in this price range (in the area of £1300-1400) I should be looking at instead?
    Many thanks.
    Cheers - Bo
  2. bobbypunk
    bobbypunk
    nsdv1000 is amazing sound and don't know why it got bad reviews
    Selling now for £700 or less!
