Sony DAVD260/sky+/bluray set up
Discussion in 'Home Cinema Buying & Building' started by shuvlyc, Feb 5, 2009.
  1. shuvlyc
    shuvlyc
    Hi all. I have just bought a sony bluray which I have connected to a philips 32pfl5532 via hdmi. I will probably be buying a sony DAVD260 tomorrow or sat and need to know what cables I need and where to stick them to connect everything together for optimum sound and vision. Ta muchly in advance.:lease:
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    youll need an optical audio cable,from blu-ray player to 260, for 5.1 audio.
    and for a video connection from 260 - tv,for watching dvd's on the 260, you will need another hdmi - hdmi lead.
  3. shuvlyc
    shuvlyc
    Ta for that, had thought I needed an optical somewhere after reading previous posts. And do I then need to change the bluray settings to optical? Am not too bothered about watching DVD's on the 260 as have the blu ray. Am only buying the 260 for surround sound as my old sony DAV SA30 is grand for DVD's but cracks at certain volumes going through the sky box. What should be connected to the sky box in new set up? There is only scart going to TV at the mo.
  4. Steeve24
    Steeve24
    Nov 25, 2008
    125
    +8
    You mentioned Sky+ as well, won't you have trouble connecting that to the 260, even if you don't want/can't get (does sky+ to 5.1?) you've used up the optical in from the Blueray?
    Also will the 260 be able to handle to audio from the Blueray, it won't have support for the HD audio formats, will it ??
    I am thinking about getting the 260 as well, originally thought about the Sony 1300 as it has more connections (future proof), but the cost vs the 260 put me off, I decided that I could live with ditching the 260 and getting something else if I go Blueray in the future,
  5. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    if he doesnt care about HD audio, then he could use an optical switch, to allow 2 or more items to connect to 1 optical input,on the 260.
    but he will still get DD5.1/DTS5.1 from blu-ray,with an optical audio lead.
  6. Steeve24
    Steeve24
    Nov 25, 2008
    125
    +8
    Yes quite right, I was thinking of getting a switch if/when I got the 260 to connect up Sky & the audio from the TV (builtin Freeview)
  7. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
  8. Steeve24
    Steeve24
    Nov 25, 2008
    125
    +8
  9. BigDelmonk
    BigDelmonk
    Feb 6, 2009
    2
    I am thinking of also getting the DAVD260, can someone tell me - is the speaker cable fixed? If not what gear do i need to install new cable, other than decent speaker cable. i.e. Do i need banana plugs etc?
    Cheers,
  10. shuvlyc
    shuvlyc
    Ta everybody, all up and running and everything looks and sounds great. Set up as follows:
    1. Scart from sky+ to TV
    2.Scart from 260 to sky+
    3.Hdmi from Blu ray to TV
    4.Hdmi from 260 to TV
    5.Optical from 260 to Bluray
    With a bit of jigging around with the settings I now have 5:1 with everything, am a happy bunny, although neighbour prob not so happy....:clap:
  11. akamrc1967
    akamrc1967
    Jan 20, 2009
    16
    should be picking one of these up today from currys (£129.99) - will the above set up work with a normal sky box.
  12. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    except sky+, thats stereo,as scart doesnt pass 5.1,only stereo, you need optical from sky+ for 5.1, so you will be getting stereo with rear echo.(pro logic, i suspect).
