Sony DAVC770 - NTSC
Discussion in 'Home Cinema Buying & Building' started by dolph, Mar 11, 2003.
  1. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    I have on this site that Sony TV's need to be played around with to get them to automatically accept an NTSC S-Video signal - however when I tried a region 1 disc with my DAV hooked up into my KV28FX66, the TV played it fine?
    There are two reasons I can think this would happen -
    1. The Sony is set up to accept the signal fine, in which case is this something Sony are now doing different.
    or
    2. The DAV is converting the NTSC signal to PAL - I'm not so sure this is the case as the DAV specifically shows NTSC on the screen when playing region 1 dvds?
    Whats going on!?!?
