Sony DAV300
Discussion in 'Home Cinema Buying & Building' started by bob mushroom, Apr 25, 2003.
  1. bob mushroom
    bob mushroom
    Jan 26, 2003
    790
    +22
    I have a DAV 300 system that after 2 years has decided that it does not wish to read dvd's any more.
    After inserting a disk it spins around then states "no disk"
    I can eject and reload a few times and then it will play!!!
    What is up with my machine - is it dead or is it just a case of buying a lens cleaning disk?
    I am loathe to buy a disk if it is beyond repair
    Please help!!
  2. MrCisco
    MrCisco
    May 13, 2005
    159
    +8
    I too have had this problem.. except it refuses to play all disks with 'no disk'.. tried a lens cleaner, no joy.. There are lots of people with the same problem.. I had a response from a good chap :
    http://www.avforums.com/forums/showthread.php?t=212414
    but also saw some info about trying to repair, if it is not the laser:
    http://www.benmorris.net/dvd/
    Personally, I wont be buying a sony dvd player ever again...
    Good luck!
