Sony DAV300 or JVC TH-A5R
Discussion in 'AV Receivers & Amplifiers' started by davidgirecourt, Mar 19, 2002.
Tags:
  1. davidgirecourt
    davidgirecourt
    I am buying a home cinema this evening but still hesitate between 2 systems, if you have the slightest idea which one is better please help me.
    David
  2. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Although most people would not recommend 'all-in-one' systems, they are quite good for those with limited space or a tight budget. The Sony DAV-S300 received excellent reviews when it was launched , but the JVC does seem like a good system too. You should try and get a demo of both systems to judge which will be better for your setup.
  3. Doubledoom
    Doubledoom
    Read the forum back over the last 2-3 months and you will find that most of the regulars hate the all-in-ones, in particular the Sony DAV.
    It is mainly down to price and what you get for the price. Some say it is snobbery but it is nothing of the sort as a couple of the alternatives mentioned are also all-in-ones.
    Magazine reviews of all-in-ones are not reliable as they treat all-in-ones as their own catagory and do not put them up against separates.
