Sony DAV SR range
Discussion in 'Home Cinema Buying & Building' started by thelord, Jan 24, 2005.
  1. thelord
    thelord
    Jun 10, 2004
    12
    I recently purchased the Sony KV36 100B Tele, and its brilliant. Even the sound is really good however I want to improve it further and upgrade to a home cinema system. I really like the look of the new SR range from Sony. I have a budget of £250 and the SR1 is now just £245 from QED (£399 from John Lewis). I understand from reading all the reviews on this site that the Denon 500 system is the dogs wangers, but I cannot afford it!!
    I have been searching for reviews on the SR1 and cannot find any. Does anyone know much about it?
  2. Adam Min
    Adam Min
    You'll find you won't get much feedback on this forum on anything other than Denon systems !! :rolleyes:
    I looked at the Sony system but like you couldn't get any advice on it. In the end I went for the Pioneer DCS 424 and am dead chuffed with it.
    However, its all down to personal taste - I would get yourself down to a retailer and have a look and listen and if you like then buy. :)
  3. thelord
    thelord
    Jun 10, 2004
    12
    I am getting that feeling. Hopefully someone out there knows about it
  4. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Not true, everybody starts somewhere and most of us start/started with all in one kits and build from there.
    Its just once people start down the AV fanatical route it kinda overtakes a little and you end up - well, upgrading (for the better of course)! :)
    Sony make very good all-in-one cinemas, they have masses of functions and reach a good level of performance per £££ for starter kits.
    CH
