sony DAV-SC5---DIVX?
Discussion in 'AV Receivers & Amplifiers' started by chadchandler, Mar 9, 2005.
Tags:
  1. chadchandler
    chadchandler
    Does anyone know if this unit can be re-programed to except DIVX files or is it a hardware thing??
    Many thanks.
  2. thelordmagus
    thelordmagus
    Dec 11, 2004
    138
    Paris
    If a machine does not natively support divx, or any other encoding format then it's not possible to reprgram the machine. Most divx capable players have a special hardware decoder for this. It's like asking a standard CD player to play MP3s.
  3. chadchandler
    chadchandler
    Many thanks for that, this means i have some sucking up to do to the wife to try and get a DIVX player next!!! :confused:
  4. trevor g
    trevor g
    chadchandler the tosh 340e i use will play divx on cdr all day long perfectly if that is
    any help to you
