Sony DAV-SB500W
Discussion in 'Home Cinema Buying & Building' started by Kryton3000, Apr 8, 2005.
  1. Kryton3000
    Kryton3000
    could someone that owns a Sony DAV-SB500W tell me if it has an optical input to connect a Sky + box to it and take advantage of the surround sound.
    I read a post saying the DAV-SB300 (non wireless version) didnt but somewhere on the internet it says it the DAV-SB500W does have one.
  2. Camperman
    Camperman
    Apr 8, 2005
    40
    According to the manual on the Sony website the DAV-SB500W does not have opitcal input. It has only two audio jacks.
    :rolleyes:
  3. Kryton3000
    Kryton3000
    How do you get the manual from the web site? Sony's web site didnt even list the product when I looked.
  4. Camperman
    Camperman
    Apr 8, 2005
    40
    Try this
    http://pdf.crse.com/manuals/2108851112.pdf
    If not you have to go into support, then into FAQ,s manuals and downloads then on the right list go into user manuals and search for the model. You need to enter it as Home Audio, DVD Player and it will come up with a list the DAV-SB500W is listed there.
    :thumbsup:
  5. MCCURLEY
    MCCURLEY
    Sep 29, 2004
    33
    I had the same problem finding info on the sony dav sb300.
    I can now tell you that it definately does not have an optical input.
    However I can also tell you that the dav sb500w doesn't either. I checked it out in my local curry's store where they had one on display.
    They told me for an optical input and wireless rear speakers I could go for the sony dav sr4 it was very similar and did have an optical input. I seen some websites that said the 500w had an optical in but the one I saw definately didn't.
