Sony DAV-SB500w / DAV-SB300
Discussion in 'Home Cinema Buying & Building' started by Paul Grainger, Dec 26, 2004.
  1. Paul Grainger
    Paul Grainger
    Nov 6, 2004
    2
    If anyone has one of these systems and wishes to upgrade to multi-region, then it can be done very easily using the 'standard' pronto CCF file. The DAV series units are not named in the compatibility list, but the hack works fine.
    The single press button sequence in used (ie 1,2,3,4,5), the unit must be in engineer mode before you start (ie no disc, press eject / stop / vol up at same time).
    The display will show 'data rst' when the mod has been done, turn it off using the normal remote, power it down for a few seconds (plug out), then voila - instant multi-region.
    Paul G
  2. nokiauk
    nokiauk
    Dec 28, 2004
    873
    Edinburgh
    +47
    do i need an additional code or something for this can't see any function to change region in engineer menu or using standard remote?
  3. Paul Grainger
    Paul Grainger
    Nov 6, 2004
    2
    You need a Phillips Pronto programmable remote control unit, plus the CCF file to download into the Pronto. There is no user selectable region option from the engineers menu - this mod cannot be done without a programmable remote control (actually I believe that it can also be done using a laptop with an infra red port plus suitable software that is readily available for free download, but it's much easier with a Pronto)
    Paul G
  4. mmc1
    mmc1
  5. rudigeld
    rudigeld
    Hi Paul, mmc1 & nokiauk,
    Where Can I find the correct CCF file for the DAV-SB500W as well as the correct free software to try the Infra Red option programming the Sony via a Notebook Computer. It is impossible to find Pronto Remotes here in South Africa!!
    Your help would be appreciated!!!
    Rudi Geldenhuys
