Sony DAV-SA30
Discussion in 'Home Cinema Buying & Building' started by Frazal666, Dec 28, 2004.
  1. Frazal666
    Frazal666
    Hello everyone, does any1 know if the Sony DAV-SA30 has optical input and AUX Inputs? Also, does this have dolby Pro Logic 2? Thanks in Advance
  2. Adil
    Adil
    no optical input, does have 2 AUX inputs through R/L RCA jacks
    It has dolby pro logic 2 which can be used by the inbuilt dvd player or from the audio input sources, and has DTS/DD which the dvd player uses
    off topic.. but does know where i can get a replacement transformer for the SA30, mine's begun to make a humming noise, also need a replacement remote
