Sony DAV S800
Discussion in 'Home Cinema Buying & Building' started by Salem Saberhagen, Apr 3, 2002.
  1. Salem Saberhagen
    Salem Saberhagen
    Does anyone know if there is a way to output the DVD audio from this deck into a seperate amp via the optical connector.
    It will output sound from CD in this way, no problem at all, but am I missing something in a menu somewhere or is my friend going to have to bite the bullet and change player as well.
    Any ideas ?
    Salem
  2. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    If it has a line out (i.e for a MD) then you should be ok, if its not listed on the rear then no you cannot, there won`t be anything in the menus for this, it will just listed on the rear connections if its available. I don`t think the DAVS800 has this though, all in ones don`t usually have this option, as they are not designed to be "upgradable!"
