Sony DAV-S800
Discussion in 'Home Cinema Buying & Building' started by Dandaman, Sep 9, 2001.
  1. Dandaman
    Dandaman
    Anyone know if an official release date for the UK has been set yet?
    Also, anyone know of places to pre-order? I know you can preorder at the Sony Centre for £799, but Techtronics are about £100 cheaper.
  2. Craig_Nike
    Craig_Nike
    Is the DAV 800 a all in one system or just a grouping of like Sony components to make up a full system ?<br />There is a DAV L8000 on the US website which is seperate components. Also there is a DAV 700 which is 5 disk and SACD - but I have not seen DAV 800 ?
  3. ScottGreatorex
    ScottGreatorex
    its out now. its an all in one system but for £800 you can get better seperately, much better but it does have multi channel SACD with sounds quite nice. it is only 50 watts a channel
    you local sony centre should have it we do
    cheers<br />scott
  4. Doubledoom
    Doubledoom
    I wouldn't touch any of the DAV range.
    None of them have scart sockets or component out. Therefore no auto-widescreen switching (handled via scart pin 8) and no RGB signal.
  5. quango
    quango
    buy any 32inch sony from JL and they'll knock £150 off the price of a DAVS800! hold on, it gets better! price match it first (from the www) and they'll still knock £150 off. i got mine for £484! sorted.
  6. quango
    quango
    true. i'd expect a lot more functions and features for £800. but then, i didnt pay that.....
