Sony DAV s800 replacement?
Big_Chief
Hello,
my parents have a Sony DAV S800 and the dvd player no longer works. What i would like todo is replace this unit with another dvd player which includes a USB connection so they can watch files from a USB stick.
Not looking to spend much and want to keep the existing wiring and speakers.
Any help would be appreciated.
mentm
It's very unlikely you will be able to re-use your speakers this is exactly the problem with all-in-one setups.
andymax313
You could link the DVD up to the system for sound using the video audio and send the picture straight to the tv I would have thought?
Big_Chief
probably the best thing todo would be buy a dvd or blu ray player which can also play files from a USB stick.
any suggestions?
