Sony DAV S550
Discussion in 'Home Cinema Buying & Building' started by jcb208, Dec 17, 2002.
  1. jcb208
    jcb208
    Dec 16, 2002
    69
    Can some one please advise as to the best way to link up the Sony DAV S550 to a sony KD32 DX100 tv at the moment im using a 3 phono to scart lead via the video1 out connection to the rgb scart on the tv Thanks John
  2. bobble
    bobble
    Jul 8, 2002
    160
    2
    +6
    The best connection you can get is componoent connection if your TV supports it, otherwise S-Video, either by direct connection to a S-Video socket on the TV or by a Svideo to Scart lead. Most TV's 2nd or 3rd scart socket supports S-Video. Dont bother connecting the audio out as you will only have to turn the volume down on the TV when using the DAV unit.
  3. jcb208
    jcb208
    Dec 16, 2002
    69
    Thanks for that advice.My tv has 2 rgb scarts and a s-video scart, Which one will work best and what lead do I need to purchase Thanks
