Sony DAV-S550 problem "READING" the DVD - is my unit faulty ?
Discussion in 'Home Cinema Buying & Building' started by bedders, May 18, 2003.
  1. bedders
    bedders
    Apr 29, 2003
    224
    UK
    Is my 10 day old multi-region Sony DAV-S550 faulty?
    Whilst watching disk 2 of Minority Report, the movie just stopped playing and the DAV-S550 went back to it's splash-screen with the words "READING" on the display.
    Now it just says "READING" for any DVD I try. You can hear kinda clicking noises while is says this, but you can't hear the disk spinning at all :(
    I'm guessing it's faulty and needs to go back to RS for a new one, but just wondered if anyone has seen this before and has any tips for a quick fix?
    Many thanks in advance.
  2. ChrisNic
    ChrisNic
    May 11, 2003
    1,922
    63
    Thame
    +111
    Sounds pretty terminal doesnt it. Doesnt sound like your going to get a quick fix for it. Lucky that its only 10 days old not a year.
  3. mark42
    mark42
    I too have had the same problems with reading problems whilst playing all sorts of disc's. I've had three players all with the same fault from 247electrical, since October of last year! Have you managed to get your problem sorted out???
  4. Adam M
    Adam M
    Oct 18, 2001
    756
    London
    +19
    I had the same problem with I bought from techtronics.
    I sent it back to have it fixed and 5 months later I just got it back.
    if it happens I don't know if I will bother with them and just go straight to sony! or possibly get them to.
