Sony DAV- S550 or SA30?
Discussion in 'Home Cinema Buying & Building' started by Philsan, Nov 8, 2003.
  1. Philsan
    Philsan
    Thank you very much!
  2. didgit
    didgit
    I would say you get more for your money with the DAV-S550
  3. DDDavo
    DDDavo
    hi
    The Davs 550, no doubt. Doesn't have scart output, not sure about the erm other model. Personally, it looks better, it has more power (output vol) and its cheap cos its been discontinued!
  4. Philsan
    Philsan
    Are you sure?
    The four reviews on What Home Cinema I've read of the S550 are not so good.
    The only review I've found regarding the SA30 on What Home Cinema is positive.
  5. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Its very hard to choose between them without more input but on a simple level I would say the S550 has better sound and the the SA30 a better picture but really its all down to what your going to use them for and what existing equipment you have. Personally I'm not a great fan of either and would say theres better systems out there with superior sound and vision for similar money.
  6. Philsan
    Philsan
    So, what system do you recommend at this price level?
    This would be my first home theatre system.
    I've considered Sony because it has SACD.
